Sumitomo SH240-5 error code 7003 and 0335
#3
hepl Sumitomo SH240-5 error code 7003 and 0335. when turn On key the display warning ELEC.PROBLEM. Thanksss!!!
If you have proble code error 7003 this is problem from N2 pressure sensor.
you can check your electrical : N2 pressure sensor GND short / open 7003 ○ from the ignition switch is turned on without voltage ≦ 0.25 V 0.25 V Supply short-circuit voltage ≧ 4.75 V
for code error 0335 problem because crankshaft position sensor system
